Last night was a serious milestone!
The footholds are glassed in, and ALL the foam is poured.
The only thing remaining is for me to glass over the foam pour holes.
I've got a bunch of pictures, but won't be able to post them until later this week - (sorry!)
So....
The big question you've all been waiting to hear the answer for - HOW MUCH DOES IT WEIGH?
final weight came to:
88 pounds.
I am stoked!
I was pretty scared when the top and bottom glued together were 78 lbs - and I still had to add all the reinforcing, footholds, and foam.
Not only is this thing 37 lbs lighter than my old hull, its every bit as bulletproof, if not more!
On a small side note, I am dissapointed with the 3 lb foam from US Composites. It doesn't expand fast enough compared to how quickly it hardens. What I mean is, a skin will form before all the cavities are fully filled, and the rest of the expansion just pushes a mass around. The 2 lb foam I used on my old hull was from Fiberlay and it fille cavities in a far superior fashion. It's still foamed, and sealed, and strong, so the result is the same.
Painting begins on Saturday at 8:00 am!!!
