Ahhh, pvc exhaust!!!
Looks good Matt, the black head looks cool.
What's the matter with the start/stop switch? Maybe I can help?
It's about time you kept up the good work.
. . . and get better pulse lines.
Well done bro. Well done. :arms::arms::arms:
I think it's NTLIE (Newbie Total Loss Installation Error). I don't have a ground from the mount plate to the motor. The starter solenoid is grounded to the mount plate...and that's it.
However, I also checked continuity in my red/brown wires when I push the start button, and there's nothing. I even took apart the safety lanyard switch and physically jumped the two copper lands for the red/brown wires. Still nothing. I'll do more investigating tomorrow.
You really should run a heavy gauge ground cable from the plate to the battery.
It is essential for the coil(s) and the brain to have good ground.
As for your start switch, I would suspect the wiring at the connectors is faulty.
What's wrong with those pulse lines?
Easy way to check: Unplug the trigger from the brain.. Short the two wires going to the brain.
That should trigger a spark.
Did you properly shim the trigger(s)?
