Okay....it rides a little bit more nose-high, as you would expect.
Turns are quicker, as if the ski responds to steering input faster than it did before. Again, I guess I'd expect that, since the nozzle sticks out further (essentially a set-back pump) and there is less hull in the water than before.
Same with rider input - the ski responds faster to it.
It makes for a more squirrelly ride, but I like that. Keep in mind that I shorted my pole setup and lost 40lbs of weight at the same time.
The ski feels a bit smaller now, perhaps because it responds better and turns faster?
Carving: Probably has more to do with the Tubbies, but it just carves really nice. Bars can touch the water, that's how well it carves.
That said, unweight the rear a bit, or turn rapidly, and the back end will slide around instantly. It definitely didn't do that before.
Now, the stock D-cut rideplate is still at stock length. I intend to cut that down a little and see what that does.
