- Rincon Beach
I got a fourth 1/2 in hard line installed and will run the stock yamaha siphon bulge
. If someone could make a smart scupper that would stay closed upside down (magnet, weighted cam, whatever) it would be one small step for mankind .
I think the scupper (xmetal) works very well on the superfreak. They are great in surf and flat. I have had ski upside down in surf for awhile without issue.
HOWEVER, i prefer and recommend a bilge pump for a backup. It will not run except after a sub or particularly wet trick/fall. When it comes on it will alert you to a problem. I had a waterline leak that bilge alerted me to. Once had a piece of turf from batt box that was stuck behind scupper causing leak that bilge picked up. Finally i had long exhaust hose pop off at the bulkhead and again bilge saved ski from sinking.
no one way check valve. what am i gona do if it breaks. yes cut my nice hull. not a good ideahaha.
and carl that was i very good idea. ive been thinking about making a spring loaded scupper with a bilge pump holding it open.
so when the there is water in the hull the bilgepump would use waterpressure it builds up to open the scupper. if it tips over the pump will not get any water and the pressure of the pumping air wouldnt be enough to open it.
just an idea but it has some flaws :d like when you are standing still if water was in the hull. it would be pumped open(maybe) and let water in to the hull. so then i thought about running a maxiplug in the scupper tube close to the bulkhead and that would help with that problem. but then there is starting to be alot of crappy stuff in there. so i gave up on this idea.
No scupper on mine and I couldn't be happier.
Works awesome.
My new 1L motor should be done in a month or so and I just bought a 148 mag, too.
Toying with the idea of a PFP, as well. I'll probably just get everything dialed in with a B-pipe first and get used to the power first.
