NVJAY775
My home away from home.
- Gardnerville, Nevada, United States
That's an effin awesome video fellas!! Yahhhhh.
It's been a while since this thread was talked about, I guess everyone is too busy putting their builds together?
I going with the next gen x-metal box, I hear that is a good fit.
I put the new xmetal box in mine the other day and the fit is damn near perfect. The only issue is it may require me to cut a little off the exhaust side because the outlet is so tall. It also seemed to leave plenty of room between the tank and box.
Some observations from my build:
- Double-check all your bolt lengths. Many inserts are shorter than stock to allow for the super-low profile of the ski. You don't want to break stuff with bolts that are too long.
- If you are getting the integrated front foothold, the standard coupler cover will not fit. You need to cut it in half lengthwise and perhaps grind some material off the top.
- Don't put the ebox over too far to the pipe side. The ebox cap will interfere with the head pipe.
- The hull sides are so thin that a standard bilge fitting will have the nut bottom out before the fitting is snug. Use an o-ring or a washer behind the nut from the bilge side.
- When you glue in the hood seal, be sure that the front-most portion is as far back as possible.
- Make sure your hood side hood hooks are on the right way and not flipped 180 degrees.
- You can most definetely fit two 500GPH bilge pumps by the midshaft.
- Lock-tite your trim & steering nozzle bolts.
- Hang the
on. This hull is ridiculous.
I am at that same stage. I just put 25mm on the middle. I sanded the center down so the hump wasn't as big. I probably have closer to 8mm thickness in the center. I'm not sure how thick I can go in the holds. Was planning on just 8mm.
Won't have time to work on it again until later in the week. I borrowed a Motorhome off the lot last weekend to take to Talledega. On the way home I destroyed a Coyote and did a bunch of fiberglass damage. My next week of nights will now be fixing that. Sucks......
