Idok
F1pro
- Nations oldest muthaF+++kin city
Seen this one too:
Installing a yamaha flywheel and making sure its nice and tight only to realize the bendix is still sitting on the bench.
oh
Seen this one too:
I've done that so many times.Seen this one too:
Seen this one too:
we dont talk about that anymore
Seen this one too:
HA HA! Guity! I've done that before
First time I rebuilt my SJ motor I installed the rear crank seal backwards, thinking the three little tabs were spacers, I installed them facing the inner seal. After like 2 rides, the seal poped out of the cases but the motor still ran fine. I called Art from Jetworks baffeled as to what happened and he nailed the problem right off and informed me of the correct installation. Of course I had to do a whole tear down to fix it.
i have done the same thing word for word.
Building a Kawi instead of a Yami.
Buying a Sxr and then spending countless years trying to make it a capable freestyle ski.............
Joining the x and realizing that I just wasted 3 years of my life . Fml
When I was a teenager we had a 300SX, completely stock (no electric bilge). It got a little filled with water doing subs and whatnot, I came into the beach as it was my 180lb fathers turn to ride. He said we should drain it and I said he could just ride it and the (stock) bilge would drain the water. Well he managed to get it up to a whopping 5km/h or so and dumped it on the intake side.
We drained it after that and it ran for a whole 5 minutes before burning the shiite out of the lower rod bearing.
Seen this one too:
I once did a stator ohm check and the numbers looked in spec, changed a voltage regulator thinking that's why my battery would not charge. Put it all back together only to later find out that the lightning coil wires would ohm 1.4 until you wiggle the wires...always check the wires also when doing ohm checks ! rookie mistake !
