OCD Solutions
- Rentz, GA
A co-worker pulled up beside me in the parking lot today and stuffed some scrap aluminum in my truck.
I need some friends like that!A co-worker pulled up beside me in the parking lot today and stuffed some scrap aluminum in my truck.
l take this will improve performance and/or gas mileage? Please explainThrottle body adapter (pre cleanup and port matching) to bolt a 2001 tundra tb onto an 05/06 manifold.
Sean![]()
Prerty much nailed it. The newer 05/06 tundras came with 40 more hp than the old ones like my 01, part of that is the vvti heads flow more but part is the better manifold.l take this will improve performance and/or gas mileage? Please explain
hello OCD, i have a question i would like to ask you in regards to a yamaha Stator for fx svho 2017, is there a way i can contact you directly.We seem to have a pretty handy group of guys who are always fabbing up something so rather than blow up the other threads, how about a spot to post up the side projects that we all want to share?
I recently completed a Grizzly G0704 Mill CNC conversion but still have tons of little things to build and tinker with. First on my list has been a proper misting system to cool and lubricate my bits during bigger cuts. Since they want $350 for $100 of parts, I chose to build my own. The reservoir was the easy part but it took me several attempts before I was able to come up with a working mixing valve.
It finally came to me last night and this is what I ended up with this morning;
That should be an awesome ride. The stx hull is great. Yes a little wet compared to the ultra but it tracks really good. Just make sure the metal plate that gets glued down were the drive shaft cones through also get screwed down. I guess that means if your using that method. I would personally try to eliminate that and mold in a flange that’s a rubber hose can clamp too like the yamahas n SDs to where it connects to bulkhead with bearing housing.Adapter plates to bolt a 255hp rotax into a kawasaki stx hull. The pump adapter I had help cutting since I don't have a lathe.
Sean
I'm excited about getting it done, this hull is getting the full workup with pneumatic trim tabs and the doo 159mm pump with trim. For simplicitys sake, I am going to run the seadoo carbon seal and just fabricate a thru hull tube and run it like a rxt-x does. It should be close to 80 mph when I finish it.That should be an awesome ride. The stx hull is great. Yes a little wet compared to the ultra but it tracks really good. Just make sure the metal plate that gets glued down were the drive shaft cones through also get screwed down. I guess that means if your using that method. I would personally try to eliminate that and mold in a flange that’s a rubber hose can clamp too like the yamahas n SDs to where it connects to bulkhead with bearing housing.
