- Loveland Colorado
looks good
You can order a brand new factory pipe at Factorypipedeal.com
Good infoThe wishlist thread! ---> http://www.x-h2o.com/threads/95529-Your-X2-wish-list Post in this link to describe your perfect X2, even if they are mods you would never be able to do yourself so others maybe someone else can benefit from your idea.
Modifications are italicized. General information is not.
Hull related mods
How much should I cut? (Poll on how much to shorten the hull for freeride) ---> http://www.x-h2o.com/threads/116678-Optimum-length-to-shorten-a-X2 (PWC Today http://www.pwctoday.com/showthread.php?t=375148)
X2 vs SJ, a side by side comparison ---> http://www.x-h2o.com/threads/102399-X2-vs-SJ-A-side-by-side...&p=1184654#post1184654
Rad Dudes X2 STA Surf Brace w/ option Ebox mount ---> http://www.x-h2o.com/threads/75729-Rad-Dudes-X2-STA-Surf-Brace
Ryan's Seat Latch Mod ---> http://www.x-h2o.com/threads/76937-seat-latch-mod.
Tom21 Custom X2 tubbies ---> http://www.x-h2o.com/threads/42599
Tubbie II install ---> http://www.x-h2o.com/threads/1699, http://x-h2o.com/threads/25615
Exhaust moving ---> http://x-h2o.com/threads/25341, http://x-h2o.com/threads/9541, http://x-h2o.com/threads/20390
Footholds ---> http://x-h2o.com/threads/19266, http://x-h2o.com/threads/8493
fitting dual carbs, Modifying the supports ---> http://x-h2o.com/threads/9256, http://x-h2o.com/threads/5823
Hood mods ---> http://x-h2o.com/threads/6295
Aftermarket Hull ---> http://x-h2o.com/threads/23469
Paint, by rustolium ---> http://www.rickwrench.com/50dollarpaint.html
Ride plates ---> http://x-h2o.com/threads/25713
Fiberglass help ---> http://x-h2o.com/threads/26011
What's inside the tray of a stock X2 ---> http://www.x-h2o.com/threads/28358/post-434443&posted=1#post434443 (see posts 51-53)
Driveline, steering, etc mods
Upgrading to a 750 pump to match your 750 engine ---> http://x-h2o.com/threads/25517
Freestyle trim ---> http://x-h2o.com/threads/19267, http://x-h2o.com/threads/31107
Aftermarket steering ---> http://x-h2o.com/threads/17066
Chin pad ---> http://x-h2o.com/threads/8658
Impellers ---> http://x-h2o.com/threads/10372
Drive shaft ---> http://x-h2o.com/threads/6744
Pump reconditioning/resleeving ---> http://x-h2o.com/threads/28416, http://www.x-h2o.com/threads/102392-prop-binding
Tail Cones ---> http://www.x-h2o.com/threads/30926
powerplant mods
Fitting a Factory Pipe Products 750 Limited in your X2 ---> http://www.x-h2o.com/threads/103959-Factory-750-pipe
Group K engine write ups ---> http://www.groupk.com/docskaw.htm
Waterbox general Info ---> http://x-h2o.com/threads/26066
750 waterbox testing ---> http://x-h2o.com/threads/25408
Interchangeable 650/750 engine parts ---> http://x-h2o.com/threads/15039
Tuning ---> http://x-h2o.com/threads/25961
B Pipe conversion? ---> http://x-h2o.com/threads/25546
Seadoo 720 conversion ---> http://www.x-h2o.com/threads/30369
650 Pipe comparisons ---> http://www.x-h2o.com/threads/...pe-Comparisons
Stock 650 pipe on 750 motor ---> http://www.x-h2o.com/threads/...stock-650-pipe
Modding stock 650 pipe ---> http://www.pwctoday.com/f21/kawi-sto...ns-148631.html
Electronics mods
Start/stop switch ---> http://x-h2o.com/threads/4189, http://x-h2o.com/threads/3837, http://www.x-h2o.com/threads/20521
750 engine with 650 electronics ---> http://x-h2o.com/threads/31286
General X2 info
stock exploded parts diagrams ---> http://216.37.204.206/jetskiunlimited/kawasaki_OEM/kawasakiPWC.asp
Year-by-year changes in the stock X2 ---> http://x-h2o.com/threads/25420
Blaster VS X2 ---> http://x-h2o.com/threads/9074
X2 build threads (only threads that are detailed enough to provide help to a person who might start a build)
Aggro ---> http://x-h2o.com/threads/41275
Austin ---> http://www.x-h2o.com/threads/102539-winter-x2-build
BlueBreadTruck ---> http://x-h2o.com/threads/19490, http://x-h2o.com/threads/16581
blwnbrd ---> http://x-h2o.com/threads/13364
Crab ---> http://www.x-h2o.com/threads/9768
Hornedogg79 ---> http://www.x-h2o.com/threads/93932-Hornedogg-s-750-X2-it-s-alive
Kkosche ---> http://www.x-h2o.com/threads/94065-Kawasaki-X2-Winter-10-11-build
madscientist ---> http://www.pwctoday.com/showthread.php?t=137749
Phlipcyde ---> http://www.x-h2o.com/threads/100340-850-Freestyle-Flatdecked-X2.-5th-Rebuild-Complete!
Primetime1267 ---> http://x-h2o.com/threads/31305
Project Ski ---> http://x-h2o.com/threads/p=285864#post285864
teamkamakasi ---> http://www.pwcforums.co.uk/wiz/forum_posts.asp?TID=19064&KW=, http://x-h2o.com/threads/12897
TheCoz43 --- http://www.x-h2o.com/threads/118654-Hypnotic-Build-Kawasaki-X2-650&highlight=
Vumad ---> http://x-h2o.com/threads/p=364263#post364263, Hood redesign http://x-h2o.com/threads/28358
Wedoseadoo ---> seadoo 720 conversion http://www.x-h2o.com/threads/30369
from the Old School forum as of 10/15/07
The "Onyx G1" ---> http://www.x-h2o.com/threads/129452-Onyx-G1-Sponsored-in-part-by-Tom21
Oh wow. I had no idea it was this bad. I thought a few links here and there were bad and was going to clean it up. Almost every link has been lost. That's very disappointing.
@Big Kahuna @SuperJETT what happened here? Is this information still in existence and the links are just broken? Can this be fixed with new hyperlinks or access to an archive?
Didnt work unfortunately
