- Charlotte, NC
l like your colors together.What color paint is that anyway?
l just can't do white turf.lt ain't me...........
thanks its ppg hot lime over white primer
x2
Don, Looks really good! I wanna try it!
It looks reaaly nice,
I like the way you put the pole bolts with the nuts inside.
get it done,
props bro
WOW , Idid not know u using XS motor, What size, That Hole will flip with that much Braap.!!!!!
How is the BOB doing? l wish mine had a cool name other than the "hole".............
"Stunt" was a pretty cool name until it got tainted by our builders reputation/craftsmanship.
l'd loan you mine,but l just got it in the boat!
Well...was this the WEEKEND?
Ended up (stunt hole owners will know this) losing the hose connection between the resonator and stinger.That sucked for two hours! Finally got it back on.....
But l came up with a problem of my own making.When l mocked up the cooling lines and placed them in the tunnel,the (looking from the rear) line on the left(original water intake) is not lining up.The only l think l can do is drill the back side of the water pick up and add another barbed fitting.l'm a little hesitant to do this cause l don't know how much metal there is?
Looking good Don!
what type of hose are you using for the exhaust?
And you other stunt hole owners,please keep on my azz to get this bitch finished! l'm lazy........
